Denoise Lighting passes
Forums: Denoise Lighting passes
Moderator: aoktar
Postby xavier.altius » Mon Oct 07, 2019 11:51 am
xavier.altius Mon Oct 07, 2019 11:51 am
Hi everyone
I'm using octane V4.
Is posible to denoise the lighting passes like we do with the beauty, diffuse, reflection, etc...?
I tried everything, using a 3rd party plug-in to denoise those passes, but with not a very good result.
Thank you so much.
xavier.altius
Re: Denoise Lighting passes
Postby Raoul » Wed Oct 09, 2019 4:53 am
Raoul Wed Oct 09, 2019 4:53 am
Currently i don't think its possible.
But would be an incredibly useful feature. A lot of us render out seperate light passes to comp with . They're often quite noisy – so if theres anyway to denoise those as well – very useful for Comping.
Currently the only option is to render the whole scene again with all the other lights off.
Aoktar.. any thoughts on the potential for this? I assume its a core functionality ( not plugin)
thanks!
Raoul
Postby aoktar » Wed Oct 09, 2019 9:14 am
aoktar Wed Oct 09, 2019 9:14 am
It's not a plugin feature. Don't know is it easy or not to add in the renderer. Every denoising the every extra passes that may requires more ram/vram. It may be the obstacle.
Postby xavier.altius » Wed Oct 09, 2019 10:17 am
xavier.altius Wed Oct 09, 2019 10:17 am
Then, the only solution is to increase the max samples.
Thank you both for your responses.
xavier.altius
Return to Maxon Cinema 4D
Users browsing this forum: Google [Bot] and 19 guests
Fri Apr 19, 2024 2:44 pm [ UTC ]
