Phoenix splash and foam is treated as static geometry
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
coilbook
Can you please fix it where phoenix foam and splash is updated during animation while update static geometry is unchecked. Liquid gets treated as movable proxy but particles don't
And the second bug. During rendering the first a c ouple of frames water looks fine but in frame 3 and up not only render time went up by 100% water is now dark. Another octane mystery. :?: I am not even sure how to trouble shoot it.
paride4331
Hi coilbook,
could you shrare your sim please?
Regards
Paride
coilbook
paride4331 wrote:Hi coilbook,
Regards
Paride
hi Paride,
here is the scene. if you simulate 20 frames and then render the animation foam and splash will be static and wont update because update static geometry is off. So octane is not treating particles as movable proxies. thanks
phoenix static.zip
(36.85 KiB) Downloaded 297 times
paride4331
Hi coilbook,
thnaks, i'm testing new release, I found an issue but i'm not sure is what you said, I sent to developers.
Regads
Paride
phoenix static3.rar
(116.98 KiB) Downloaded 306 times
remKa
Hello,
did you find a way to get foam and splash animation updated ?
AMD 9950x3D / RTX 4090 / RTX 3090 / 192 Go DDR5 / Win 11
http://www.remy-kerbiquet.com
coilbook
Only with update statistic mesh checked
Return to “Bug Reports”
