Cinema 4D version 2019.1-XB2-Test1 (Experimental test ver.)
Hi all,
This is first test build with experimental SDK(2019.1-XB2). Please do not use in production environment. Any feedbacks are welcome for development and fixing the issues. Enjoy it!
This is the matching SDK for the 2019.1 XB2 Standalone.
What's new
AI Up-sampler
Composite material(old blend material)
Layered material
New material pin for Octane materials
Round edges pin for Octane materials
Vertex/Texture displacement nodes and displacement mixer (Note that disp. mixer may not work well)
New embedded GUI controls for NODE EDITOR
Texture sampling for Octane volumes
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also, make sure you use a driver of version 387 or higher and if you are working on Mac OS that has a CUDA driver installed that supports at least CUDA 9.1.
1- Try different drivers, some of them could cause instability issues. Do a clean install while doing this to be sure previous files completely removed.
WINDOWS ENTERPRISE BUILD (R15-R20)
https://render.otoy.com/customerdownloa ... B2_win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-R20)
OSX ENTERPRISE BUILD (R15-R20)
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD (R15-R20)
RES file for R15
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057). Otherwise, the plugin will not work and not appear in menus.
-Updated Nvidia drivers at least 388.xx, recommended 417.22 or 419.17 (one of most recent with Cuda 9.1) and be carreful with latest drivers which can cause cuda errors. Avoids to use 418.81.
-Cuda 9.1 driver for OSX.
ONLINE HELP MANUAL
To use OFFLINE version of manual from plugin
Download following package and extract to Cinema4D/plugins/c4doctane/manual
https://render.otoy.com/plugindownloads ... p-html.zip
V3 SAMPLE SCENES SET(make a request if you need any specific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Cinema 4D Release 20: c4dOctane-r20.xdl64 or c4doctane_R20_demo.xlib
Cinema 4D Release 21: c4dOctane-r21.xdl64 or c4doctane_R21_demo.xlib
VVG
Thanks, but where Downloads for users with a regular V4 license (for test)? like a STDL
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
thanulee
Thanks Ahmet! u rock!
mitchino
Can't wait to try the OSX Version!
eyeonestudio
Thank you. Ahmet~~
mitchino
Woah! R21? You a beta tester? Care to give us an unspecific general non-rule violating impression of the upcoming release?
miohn
just looking at the 2019 demo.
Where needs this roundEdges Pin to be plugged in please?
How does this work?
thanks
Mike
miohn wrote:Hi,
How does this work?
thanks
Mike
We Do not have 2019 demo. Where did you find it?
Singular1974
Thank you for this release. Was the AI denoiser improved? I'm noticing it's far less blotchy now on my test renders.
Felix12345
rtx support? :(
i really dont care about new features. being able to render QUICKER is way more relevant than any feature i can think of.
