Maximum Out of Core Ram
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Ilius
Hey guys
Since we've been updated to octane 4 and out-of-core can also do geometry we thougt "cool, lets buy a butt-load of ram and stick it in".
Only after refitting the computers we saw that in Cinema 4d (R19) you can only configure up to 64GB out of core ram usage.
My PC would have double that amount of RAM, now its kinda useless.
Is that a general limitation of octane?
Will this be extended?
Or is it somehow related to our machines?
Cinema R19.068
Octane V4.02.01-R2
3x NVIDIA GeForce GTX 1080Ti
Intel i7-6850K 3.60 GHz
Thanks for any reply
try to see if you can go higher in Standalone, but take into consideration that you also need RAM for handling the huge scene in c4d, and for handling frame buffer, especially with passes and/or denoiser, so you cannot use all 128GB of RAM for Out-of-core only.
Have you already tried to reach 64GB of Out-of-core?
ciao Beppe
No it's just hard-coded numbers. Why do you need so much RAM to use? Collecting for user experiences, are you using optimizations or just go straight-forward on scenes?
Ilius
Sorry with the late reply - we had much work to do in the last days and i just forgot somehow...
bepeg4d wrote:Hi,
ciao Beppe
Thanks for your thoughts, before upgrading our RAM we always worked with 60GB Ram for Octane and only 4GB remaining for the rest of Windows/Cinema Operations and it worke fine, so i guess if i could go up to a 120GB for Octane it should be fine.
Im now working with 64 GB and its also working just fine. Some Scenes cant even be handled by our other computers anymore, because they dont have the extra 4 GB RAM to spare.
aoktar wrote:No it's just hard-coded numbers. Why do you need so much RAM to use? Collecting for user experiences, are you using optimizations or just go straight-forward on scenes?
Also thanks to you for your reply,
Our Office is in the field of Architectural Renderings and I myself also work for the gaming industry as a freelancer, making Models, texturing etc.
Because of my experience with gaming i pride myself with opimization in my work for architectural scenes.
I always try to:
- reduce the poly-count of too-high poly objects to a bareable minimum whereas it is still nice to look at at a given distance (depends on scene)
- avoid doubling of textures when copy and pasting obejcts from scenes
- reduce textures to a 1k/2k depending on their importance for the scene
- use displacement only when it is close enough to the camera to actualy be seen
- use as many render-instances as i can
- avoid overlaping geometries
- no booles or other cinema-operations that could consume ram
Even with all that, we currently have overview stills to render, where we are above buildings and need to show a lot of stuff, like cars, vegetation, people, furniture inddor/outdoor (and variance in the furniture, because our client doesn't want to see too much of the same stuff) sourrounging buildings, etc.
Our polycount sometimes goes up to 11-12 million - which seems to be the magical border of octane where it either renders or gives me a black screen, even though there are claims that there is no limitation anymore.
so that is our situation.
Does hard-coded numbers mean, that they could go up in an update? I'm sorry im not familiar with programming expressions...
Ilius
bepeg4d wrote:Hi,
ciao Beppe
Well i've tried in Standalone right now and as you can see in the attachment, it could go higher in standalone.
It would still be nice to be able to go higher inside Cinema 4D, always exporting the scenes, which are huge sometimes, doesnt seem like a streamlined process
PS.: Seeing the attachmend image i am reminded that we installed some of the RAM elsewhere so sorry, i currently have 96 GB of RAM not 128GB...
Ilius
soooo, any news on that topic?
Would be nice to be able to go higher inside Cinema.
Exporting for Standalone everytime we change details is not a viable choice vor us, moreso because octane has a tendency to crash during export of big scenes.
Ilius wrote:soooo, any news on that topic?
I've changed it for next builds. Btw try to optimize your scenes for performance.
Ilius
Thanks thats nice.
and i will try furthermore
Return to “Bug Reports”
