Live View render animation
JackBecce
Hi Guys, there is a way to render from the Live viewer instead of batch render or Picture viewer render ? my scene is rendering at 6 second on Live Viewer but when I render it is taking 50 second per frame, I'm almost thinking of doing it by hand saving individual frames from LV (unfortunately is a 4000 frames animation !
Is an heavy geometry scene but onli 4 small elements are moving and the camera, I'm using tags for the static objects and so on..
the fact is that in LV everything is working really fast and I'm happy with the quality of my image, anyone got a script to save LV, advance a frame, save LV with incremental number and so on ?
You're looking at wrong direction. Picture viewer can do renders at same speed of Live Viewer. You should define why it doesn't that. Probably there's some reason to update all geometry for every frames.
JackBecce
aoktar wrote:You're looking at wrong direction. Picture viewer can do renders at same speed of Live Viewer. You should define why it doesn't that. Probably there's some reason to update all geometry for every frames.
can you help me in understanding the differences between LV computation and PV ?
in LV I can see 6GB ov Vram are used , when rendering in PV My physical RAM get filled up at 32 GB
JackBecce
Something is puzzling me, the c4d plugin seems to work better in LV ( using less memory ) when rendering in PV the geometry used it’s scaling up , like it’s translated from instances into individual objects, even if set to static, it’s that the difference?
To understand that better you should read manual. Especially quick start and rendering sections.
Btw be sure you have "All movable". So it should be same as LV. And be aware of triangle count differences between LV and PV for some objects, like subdivision or some generator objects. Other than this hard to know more without you send a better visual data.
JackBecce
aoktar wrote:To understand that better you should read manual. Especially quick start and rendering sections.
Thanks aoktar, The issue I have is that:
if I try to render in PV the software is crashing as my RAM is saturating ( whatever settings I use, movable or non movable object tags)
I've also tried exporting to orbx first with a simplified scene (and worked) but the complete scene it's taking forever (5 hours and running) only to save the abc file, surely this is caused by the triangles in the scene (37M) as I have lots of clones and instances.
for whatever reason the scene is rendering fine in LV without saturating the RAM and keeping the 2x 2080 Ti's at a reasonable 8GB load, so if I scroll through my timeline frame by frame I can easily achieve a 5 second per frame, I've manually saved one frame after the other from LV and it's a painful process when repeated for 8 hours !
I can't figure it out why this behaviour and I'm running out of time for suppling those animations, there is any chances to do a script that will repeat the manual process ?
sorry to be a pain !
My system: 2x 2080 Ti,, Intel i7-6800K 6 cores @ 3.40Ghz, 32 GB RAM, SSHD, using octane V4.04, and plugin V 4.04 R2
try to set the same subdivision for viewport and final render, for all the c4d objects with a similar setting:
ciao Beppe
As me and Beppe said, you should have similar data usage for LV vs. PV. But note that what Beppe said and be sure "All movable" selected. Otherwise engine reacts different on PV.
JackBecce
So many thanks aoktar and Bepeg4d, I finally managed to have similar results between LV and PV,
I started looking at the triangles increase in the Graphic cards monitor and they were indeed doubling up between LV and PV,
after a long research I found the assassin, it was a deeply nested cloner with an Hypernurbs object that was set to double up the subdivisions in render mode .
now I can finally go to bed....
again many thanks for your patience and suggestions.
JackBecce
bepeg4d wrote:Hi,
ciao Beppe
that was the issue Thanks Beppe
