octane does not keep a focus
michaelkk
I import a file with animation from Maya to octane using maya2octane exporter,
I set focus to the scene in Octane, But when I click "Render Animation" in maya2octane it is not renderer with the focus that I set
Anyone can help?
thanks
Windows 7 64 bit | 2x NVIDIA GTX580 | 24GB Ram
abstrax
michaelkk wrote:I import a file with animation from Maya to octane using maya2octane exporter,
Anyone can help?
thanks
It's not a bug in the exporter, but a problem in Octane. It will be fixed with the next test release planned this week.
Marcus
abstrax
Forgot to mention: What you can do in the meantime is specify the focus distance in the export plugin, which will then export it to Octane to use the right focus.
Marcus
michaelkk
abstrax wrote:Forgot to mention: What you can do in the meantime is specify the focus distance in the export plugin, which will then export it to Octane to use the right focus.
Marcus
Thanks for the answer...
How can I find the focus distance?
abstrax
Marcus
In the export plugin it's called "Focal Depth".
Marcus
michaelkk
abstrax wrote:
Marcus
Marcus
OK
But How can I find the number I need to put in Focal Depth :?:
abstrax
michaelkk wrote: OK
Either somehow in Maya (I don't know Maya) or by waiting for beta 2.48, which will do that for you :)
Marcus
face
abstrax wrote:
michaelkk wrote: OK
Marcus
Aha,
Octane calculates the distance by build the square root from the length of the subtract result vector camera to vector target.
Clever, nice new feature ;)
@michaelkk
You can also use the formular to calculate the distance in maya.
Maybe as expression...
face
http://vimeo.com/user2509578
dkalna
Hi there,
is bazuka still around? We have seen last Maya Exporter on 23.11.2010 (beta v2.5). Any updates?
Best regards,
Dalibor
Hardware: Intel® Core i7 920 2.66GHz, 12GB RAM, Gainward NVIDIA GeForce® GTX 580 1536MB GDDR5
Software: Windows® 7 Home Premium 64-bit, Autodesk® Maya® 2012 64-bit, Octane Render™ v1.0 beta 2.52
face
dkalna wrote:Hi there,
So much i know, he is bussy with some work...
face
Return to “Autodesk Maya”
