Mix HDRI?
Dar_T
Hi. Is it possible to use more than one hdri? I can only seem to use hdri and sky. Redshift allowed me to use multiple hdri domes.
in OctaneRender you can have a Primary Environment node, and add a secondary Visible Environment node, to handle the illumination with the Primary node, and handle Backplate, Reflections, and Refractions with the Visible node.
ciao Beppe
Despot
bepeg4d wrote:Hi,
ciao Beppe
Yes, but wouldn't it be great if you could have multiple visible environments, enabling the user to use one for reflection/refraction and another for backplate...
Dar_T
Ah I see. I wanted to mix the lighting of the two hdri's. Is there a way to work around this? Maybe a mix node?
Dar_T wrote:Ah I see. I wanted to mix the lighting of the two hdri's. Is there a way to work around this? Maybe a mix node?
you can use Mix node for that
