Experience with Noise-Shader and Animations?
Lubo
Hello,
did you prefer noise-shader or highres textures to generate nice little structures on surfaces in animated secene?
I`ve create a powder-coated metal with noise-shader. As a still it looks fine but in the animation it`s very noice and
it does not matter if I adapt the samples of the lights or not. Sometimes it looks like the noiseshade is not moving with the object.
Best regards
David_S
Can I take a look into your file?
best
David
Which kind of nise shader are you using?
Please post a screenshot of the node graph editor.
ciao Beppe
Lubo
Thanks for reply. Here is an expample scene with the shader I use.
Best regards
noise-testfile.zip
(89.46 KiB) Downloaded 169 times
David_S
Hi Lubo,
maybe your GI Clamp of 0.02 makes it noisy. Try a GI Clamp of 1 and adjust the lights to get the same brightness/contrast.
regards
David
Lubo
No, it`s not better. But can I say that there is no difference in the quality between using octaen noise-shader and highres textures?
