OCTANE. No CUDA GPUs Error.
shvahin
WTF, do u know?
Thx.
Gabriele makes me notice that you are working with v1.55.
Better to perform a clean installation of an older version of Nvidia drivers.
Try with 397.93, but probably you need an older version:
https://www.nvidia.com/download/driverR ... 4624/en-us
ciao Beppe
yazganarikan
Hello,
I also have the "no cuda gpu's" error.
My Octane version: 4.05 standalone
GPU: GTX Titan
1. I uninstalled all drivers via DDU.
2. I opened the software without installing any driver. It worked.
3. I installed Nvidia Driver 442.19. Same problem happened again.
4. I tried several other driver versions the same problem happened in all the instances.
5. I installed 3.08 the problem is still there.
It looks like installing a driver is preventing octane to see the graphics card.
Can you help me?
v3.08 is too old, please use v4.05, and try to perform a clean installation of 419.67 Nvidia Creator Ready driver:
https://www.nvidia.com/download/driverR ... 5178/en-us
To perform a clean installation, please follow these steps:
Then download and run GPU-Z:
https://www.techpowerup.com/gpuz/
And share a screenshot from the Graphics Card tab, for all the available Nvidia GPUs, thanks:
ciao Beppe
yazganarikan
Hello Beppe,
Thank you for the instructions,
1. I installed windows 8 version of 419.67 since my OS is W8.1
2. I performed a clean installation
3. I still see the same error in Octane 4.05
This is my GPU-Z screenshot. I see that CUDA is not marked after 419.67. ( please note that just after the DDU, I was able to see CUDA ).
please try to perform a clean installation of 442.19 driver:
https://www.nvidia.com/download/driverR ... 6775/en-us
Then run OctaneBench 4.00c and share a screenshot of the results, thanks:
https://render.otoy.com/downloads/a/787 ... 0c_win.zip
ciao Beppe
yazganarikan
Hello
I clean-installed 442.19 for Windows 8.1
I ran OctaneBench_4_00c / octane.exe and received this message: No supported GPU found
Is CUDA still unchecked in the GPU-Z panel?
You need to find an Nvidia driver greater than 419.67 that works for you.
Unfortunately I don’t have other reports from Win 8.1 users, normally it is Win 7 or Win 10. :roll:
ciao Beppe
yazganarikan
Yes CUDA is still unchecked in the GPU-Z
It is unfortunate that the problem still exists but thank you very much for your help Beppe!
I will continue exploring :)
