Dirt and bump/normal maps
benjanowitz
Hey guys,
I can't figure out how to achieve this effect in octane:
The only thing I get with the dirt node is having it on the edges of the surface but not on the normal or bumps crevices:
you need to use Octane displacement, or the c4d displace deformer, to make the dirt work as expected, here is an example with Octane Displacement and an Universal material:
universaldisplace.c4d.zip
(80.08 KiB) Downloaded 236 times
ciao Beppe
benjanowitz
Okay, as expected...displace only.
Question: why are you using the universal material?
Just for the simplicity to have all the possibility in one unique material node, without mixing materials.
ciao Beppe
grimm
Another possibility is to use a curvature map (you would have to generate it externally with Substance, or 3D-Coat, etc.) and use it to control the mix of materials.
