Hi there,
I'm trying to render out a scene about 1300 frames long and getting crashes every 200 - 300 frames.
I'm on Windows 10.
*edit* GeForce: 417.71
OR: v4.01.1 r2
How can I diagnose this issue? I've attached the bugreport.txt
Ryan
Constant crashes on v4.01.1 r2
- Attachments
- _BugReport.txt
- (511.03 KiB) Downloaded 122 times
do you mind to send me the scene via PM for checking?
If too great, you can share a link to dropbox or google drive.
ciao Beppe
ciao Beppe
Hi Beppe,
This project is NDA. But what I found out is it only crashes if I'm using Network Render.
The scene is very light : Used/Free/Total (on my primary 1080ti's): 1.232gb/8.381gb/11gb
- No large textures.
- motion blur enabled
- saving denoised only
- Kernel = Directlighting
- max. samples = 400
- GI Mode = GI_None
- adaptive sampling = 0.03 / 150
- minimize net traffic = ON
- AI light = OFF
My one render node is a Mac Pro (10.13.6) with 2x 980ti. It all works fine until frame 200 - 300.
Hope that helps. Otherwise, I can try to replicate the problem with a new scene.
Ryan
- GI Mode = GI_None
- AI light = OFF
Ryan
Hi Ryan,
please upgrade the Master to 4.02.1-R2:
viewtopic.php?f=85&t=70622
And the Slave to 4.02.1:
viewtopic.php?f=24&t=70612
Also take a look at system RAM consumption after some frames.
ciao Beppe
ciao Beppe
Thanks Beppe.
I've upgrade the Master to 4.02.1-R2 and slave to 4.02.1. Same issue when rendering over network.
I've monitored the system ram and it slowly is filled up but it still has 15 - 30gb of 60gb at all times as far as I can tell. What should I be looking for?
Ryan
Ryan
