Constant crashes on v4.01.1 r2
rutv
Hi there,
I'm trying to render out a scene about 1300 frames long and getting crashes every 200 - 300 frames.
I'm on Windows 10.
*edit* GeForce: 417.71
OR: v4.01.1 r2
How can I diagnose this issue? I've attached the bugreport.txt
Ryan
_BugReport.txt
(511.03 KiB) Downloaded 112 times
rutv
Hi Beppe,
Sorry! My mistake, I'm on 417.71.
Ryan
do you mind to send me the scene via PM for checking?
If too great, you can share a link to dropbox or google drive.
ciao Beppe
rutv
Hi Beppe,
This project is NDA. But what I found out is it only crashes if I'm using Network Render.
The scene is very light : Used/Free/Total (on my primary 1080ti's): 1.232gb/8.381gb/11gb
- No large textures.
- motion blur enabled
- saving denoised only
- Kernel = Directlighting
- max. samples = 400
- GI Mode = GI_None
- adaptive sampling = 0.03 / 150
- minimize net traffic = ON
- AI light = OFF
My one render node is a Mac Pro (10.13.6) with 2x 980ti. It all works fine until frame 200 - 300.
Hope that helps. Otherwise, I can try to replicate the problem with a new scene.
Ryan
Hi Ryan,
please upgrade the Master to 4.02.1-R2:
viewtopic.php?f=85&t=70622
And the Slave to 4.02.1:
viewtopic.php?f=24&t=70612
Also take a look at system RAM consumption after some frames.
ciao Beppe
rutv
Thanks Beppe.
I've upgrade the Master to 4.02.1-R2 and slave to 4.02.1. Same issue when rendering over network.
I've monitored the system ram and it slowly is filled up but it still has 15 - 30gb of 60gb at all times as far as I can tell. What should I be looking for?
Ryan
