CUDA error 999 (all 3 Gpu Failed) - they were running fine
manodzit
Anyone has idea about this? no renders.
Started logging on 05.02.19 13:17:35
OctaneRender 4.01.1 (4010100)
CUDA error 999 on device 1: unknown error
-> failed to link file
device 1: failed to load OSL shader code:
error : Multiple definition of 'cuSptStatistics' in 'cuda_texturenode', first defined in 'snippets_internal'
device 1: failed to compile module 1
CUDA error 999 on device 2: unknown error
device 2: failed to load OSL shader code:
device 2: failed to compile module 1
CUDA error 999 on device 0: unknown error
device 0: failed to load OSL shader code:
device 0: failed to compile module 1
device 2: failed to compile module 0
device 0: failed to compile module 0
device 1: failed to compile module 0
I will appreciate any help from you guys.
mano
paride4331
Hi manodzit,
viewtopic.php?f=9&t=70570&p=356426#p356426
Regards
Paride
manodzit
Thanks Paride! ;)
Lokken
Hey all,
I am having a similar issue, getting this message :
Started logging on 04.08.19 14:29:16
OctaneRender 3.08.4 (3080400)
-> failed to link to cubin
device 0: failed to compile OSL code:
error : Undefined reference to 'cuGeo' in '('
error : Undefined reference to 'cuParams' in '('
error : Undefined reference to 'TRANSFER_XYZ' in '('
error : Undefined reference to 'cuXyzToRgbMatrix' in '('
error : Undefined reference to 'CYAN' in '('
error : Undefined reference to 'BLUE' in '('
error : Undefined reference to 'GREEN' in '('
error : Undefined reference to 'MAGENTA' in '('
error : Undefined reference to 'RED' in '('
error : Undefined reference to 'YELLOW' in '('
error : Undefined reference to 'cu_cam' in '('
error : Undefined reference to 'cuQueues' in '('
However, i tried your advice and downloaded and installed the driver version, however i could not successfully complete the installation becuase it said " this driver is not compatible with your version of windows".
I am on Win7 64bit.
I am currently running Octane version 3 ( latest version ) and i have a GTX 1080 ( strix ROG ).
Any suggestions and/or help would be so deeply appreciated.
Thanks all,
Adam
Asus X99 workstation board / Intel Haswell Hex 5960k with H100i cooler / 32 GB corsair dominator platinum / 1200k corsair platinum PSU / 2 x 980 GTX Vanilla / 1x GTX960 Extreme / 3 x Crucial solid state / NZXT phantom 820 Case / Win 7 Ultimate
paride4331
Hi Lokken,
please use the latest OctaneRender V4.x available updating the Nvidia drivers.
Regards
Paride
Lokken
Thankyou for your response Paride!
I only have a license for octane 3, i am not purchasing version 4 at this time as i cannot afford too!
I have used the Otoy system profiler courtesy of the Otoy tech support team in the hope this will uncover the problem!
paride4331
Hi Lokken,
Octane V4 license upgrade is for free.
1 You will to sign out of Octane Standalone and any plug-in software, please follow the process as described in the Octane Manual 'Signing Out' details > https://docs.otoy.com/StandaloneH_STA/S ... Access.htm. When you sign out of your plug-in, both your Standalone and Plug-in licenses will be deactivated. (A Standalone license is always bound to a plug-in license, when a plug-in is launched).
2 you will have to upgrade your version 3 licenses to version 4. This upgrade is free and can be done via these 4 steps:
Go to https://home.otoy.com/render/octane-render/purchase/
Select "Upgrade" in the top menu.
Click on "UPGRADE NOW" next to "Upgrade existing licenses to OctaneRender 4".
Select the licenses you want to upgrade and confirm.
Regards
Paride
Lokken
I am a silly guy!
Yes, thankyou so much, i was not aware i could upgrade for free, that is truly amazing.
Thankyou so much for your replies and help.
Have an awesome week guys
Adam
