background Image to match the 3D scene inside DAZ3D
Moderator: BK
Tripledad
Hi folks,
I know it was asked several times in the past.
I tried to use a background image to match the 3D model.
No problem in Cinema4D or in Standalone.
No problem in Daz is you use Iray.
Is there really no workaround to use a background image in Daz and octane (No 360 enviroment)?
maybe I am to stupid to find a solution.
Greetings
Ralf
Sorel
Are you talking about adding an hdri?
Ralf, if you want to add a background image which does not contribute to the lighting in the scene, you will need to enable the Kernel->Alpha Channel, and then save the render and use Photoshop/GIMP/etc to composite the render over the background image.
Return to “DAZ Studio”
