OctaneRender™ 2018.1 for Houdini™ beta build 2018.1.0.3 RC3
juanjgon
This a new beta release of the OctaneRender™ 2018.1 for Houdini™ plugin compiled with the Octane 2018.1 RC3 core. This 2018.1.0.3 release is available for the Houdini 16.0/16.5/17.0 latest production builds on Windows x64, Linux gcc6.3.1 and OSX 10.12. This plugin is also compatible with Houdini Indie (While working inside the Indie version, the plugin will have a 4k limited resolution while rendering sequences and the scene export and cloud rendering features disabled)
As with all experimental releases, please do not use this for production purposes. 2018.1 RC3 will expire in 60 days
New features
To learn more about the new features and improvements of OctaneRender 2018.1, please check out the 2018.1 release post, but this a quick list of the main new features that have been added:
  • NV Link support on RTX 2080 and RTX 2080 Ti
  • Cryptomatte. Currently, in the Houdini plugin the Instance ID is used also as Object ID due to its internal scene graph architecture.
  • Vertex Attributes in the mesh objects. New options in the Octane OBJ spare parameters to configure the attributes to be extracted.
  • New "Color Vertex Attribute" and "Float Vertex Attribute" VOP nodes to retrieve the vertex attributes in the shaders.
  • Deep render passes.
  • Way less Volume Render Noise. New option in the kernels to disable this feature if the matching of the Octane v4 volumes is needed.
  • Direct Levelset surface rendering. New option in the Octane OBJ spare parameters to configure the volumes and OpenVDB rendering to work with SDFs.
  • Scatter depth limiting (i.e. fast fog rendering)
  • Overall 5% faster than V4 stable (about 315 OB vs 298 OB in our tests)
  • GPU compressed textures are now cached (big time saver for many - based on your V4 feedback )
Release 2018.1.0.3 regular license
https://render.otoy.com/customerdownloa ... _Win64.zip
https://render.otoy.com/customerdownloa ... _Linux.zip
https://render.otoy.com/customerdownloa ... ni_OSX.zip
Release 2018.1.0.3 subscription license
https://render.otoy.com/customerdownloa ... n64_vr.zip
https://render.otoy.com/customerdownloa ... nux_vr.zip
https://render.otoy.com/customerdownloa ... OSX_vr.zip
Standalone 2018.1 RC3 version for the network rendering nodes
https://render.otoy.com/customerdownloa ... C3_win.exe
https://render.otoy.com/customerdownloa ... _linux.zip
https://render.otoy.com/customerdownloa ... _macos.dmg
Release Notes
RELEASE 2018.1.0.3
* PLUGIN FEATURES AND FIXES:
- Dual support of point or vertex level attributes in the mesh objects.
- Fixed a problem in the ROP node GUI.
- Fixed a critical performance issue in the scene update code while rendering sequences to disk in scene update mode.
- Fixed several critical performance issues related to the IPR scene update.
- Support of variables like $HIP in the log file path.
- Fixed a crash after closing the IPR window while the scene is being extracted.
- Fixed the Octane light while working in blackbody mode, adding an option to enable the distribution texture.
* OCTANE FEATURES AND BUGS FIXED:
- Fixed an issue on Linux causing the computer to be identified differently if Houdini+Hython is being used. As a result a second license would have been required if Octane was
already run as Standalone or as different plugin. So Linux Houdini users should make sure licenses are deactivated before updating or else they will require to unlock their liceneses via the website.
- Fixed incorrect render restart if the noise pass gets enabled / disabled when adaptive sampling or the denoiser is enabled.
- Fixed bug that caused geometry to disappear or to render only partially on some frames of animations.
- Fixed rendering of the third UV coordinate set.
- fixed a couple of Cryptomatte crashes
- fixed geometry getting reprocessed when the camera is deleted
- fixed HDR image load crash when x-direction is flipped
- fixed volume SDF not working with specular material or medium
- fixed VDB exporter crash.
- fixed banding in larger scales of SDFs.
- improved SDF tracing speed when there is scaling in the instance
- fixed volume SDF normals when an instance is rotated and/or scaled
- reduced memory usage of vertex attributes
- fixed rendering of second color vertex attribute if a mesh contains also float vertex attributes.
- increase the max seeding samples for Cryptomatte to avoid getting black pixels on soft edges.
- fix possible crash when using a "mapper" input for a string input parameter in an OSL shader.
- Temporarily disabled caching of baking texture node for input texture types that are not image textures, since it wasn't working as intended yet.
- Fixed Automatic pixel format setting which would still load 32bit float EXR images and HDR images as 16-bit float.
Happy rendering,
Your OTOY Team
ouyeantai
bug report
Same shader setup for displacement map. It work perfectly in /shop level but didn't work in /mat level.
juanjgon
ouyeantai wrote:bug report
Can you please attach an example scene to reproduce this problem here?
ouyeantai
hello Juanjo,
When I try to open the scene file to reproduce the problem. I'm getting a message which stop me to start ipr. I just updated to the lastest nvidia driver.
Houdini FX Version 17.0.467
Operating System: Windows 10 Enterprise x64
Number of Cores: 64
Physical Memory: 127.89 GB
Number of Screens: 1
Screen 0: 1680 x 1050 at 0,0
Work Area 0: 1680 x 1020 at 0,0
Build platform: windows-x86_64-cl19.16
Qt Version: 5.6.1
OpenGL Vendor: NVIDIA Corporation
OpenGL Renderer: GeForce GTX 1070/PCIe/SSE2
OpenGL Version: 4.6.0 NVIDIA 418.81
OpenGL Shading Language: 4.60 NVIDIA
Detected: NVidia Consumer
8192 MB
418.81.0.0
Supported Extensions not in OpenGL 3.3 (Version):
EXT_extensions_string
GL_ARB_base_instance (4.2)
GL_ARB_bindless_texture
GL_ARB_buffer_storage (4.4)
GL_ARB_compatibility
GL_ARB_compute_shader (4.3)
GL_ARB_debug_output
GL_ARB_gpu_shader5 (4.0)
GL_ARB_gpu_shader_fp64 (4.0)
GL_ARB_multi_bind (4.4)
GL_ARB_program_interface_query (4.3)
GL_ARB_robustness
GL_ARB_sample_shading (4.0)
GL_ARB_separate_shader_objects (4.1)
GL_ARB_shader_image_load_store (4.2)
GL_ARB_shader_storage_buffer_object (4.3)
GL_ARB_shading_language_packing (4.2)
GL_ARB_tessellation_shader (4.0)
GL_ARB_texture_buffer_object_rgb32 (4.0)
GL_ARB_texture_filter_anisotropic (4.6)
GL_ARB_transform_feedback3 (4.0)
GL_ARB_vertex_attrib_64bit (4.1)
GL_EXT_abgr
GL_EXT_blend_minmax
GL_EXT_direct_state_access
GL_KHR_debug (4.3)
GL_NVX_gpu_memory_info
GL_NV_gpu_shader5
WGL_EXT_swap_control
Unsupported OpenGL Extensions used by Houdini:
GL_ATI_meminfo
OpenGL Limits:
ELEMENTS_VERTICES 1048576
ELEMENTS_INDICES 1048576
VERTEX_UNITS 32
TESS_CONTROL_TEXTURE_IMAGE_UNITS 32
TESS_EVALUATION_TEXTURE_IMAGE_UNITS 32
GEOMETRY_UNITS 32
FRAGMENT_IMAGE_UNITS 32
COMBINED_UNITS 192
TEXTURE_SIZE 32768
3D_TEXTURE_SIZE 16384
CUBE_MAP_TEXTURE_SIZE 32768
RECTANGLE_TEXTURE_SIZE 32768
TEXTURE_ARRAY_LAYERS 2048
MAX_COLOR_TEXTURE_SAMPLES 32
MAX_DEPTH_TEXTURE_SAMPLES 32
FBO_ATTACHMENTS 8
DRAW_BUFFERS 8
VIEWPORT_DIMS 32768x32768
VERTEX_UNIFORMS 4096
FRAGMENT_UNIFORMS 4096
VERTEX_ATTRIBS 16
VERTEX_OUTPUT_COMPONENTS 128
MAX_CLIP_DISTANCES 8
PATCH_VERTICES 32
TESS_GEN_LEVEL 64
TESS_PATCH_COMPONENTS 120
TESS_CONTROL_OUTPUT_COMPONENTS 128
TESS_CONTROL_TOTAL_OUTPUT_COMPONENTS 4216
TESS_EVALUATION_OUTPUT_COMPONENTS 128
GEOMETRY_UNIFORM_COMPONENTS 2048
GEOMETRY_INPUT_COMPONENTS 128
GEOMETRY_OUTPUT_COMPONENTS 128
GEOMETRY_TOTAL_OUTPUT_COMPONENTS 1024
GEOMETRY_OUTPUT_VERTICES 1024
UNIFORM_BLOCKS 84
UNIFORM_BLOCK_SIZE 65536
UNIFORM_BUFFER_BINDINGS 84
COMBINED_VERT_UNIFORM_BLOCKS 14
COMBINED_VERT_UNIFORM_COMPS 233472
TESS_CONTROL_UNIFORM_BLOCKS 14
TESS_CONTROL_UNIFORM_COMPONENTS 2048
TESS_EVALUATION_UNIFORM_BLOCKS 14
TESS_EVALUATION_UNIFORM_COMPONENTS 2048
COMBINED_GEO_UNIFORM_BLOCKS 14
COMBINED_GEO_UNIFORM_COMPS 231424
COMBINED_FRAG_UNIFORM_BLOCKS 14
COMBINED_FRAG_UNIFORM_COMPS 233472
MAX_FRAGMENT_STORAGE_BLOCKS 16
MAX_STORAGE_BLOCK_BINDINGS 96
TRANSFORM_FEEDBACK_INT_COMPS 128
TRANSFORM_FEEDBACK_SEP_COMPS 4
TRANSFORM_FEEDBACK_SEP_ATTRIBS 4
LINE_WIDTH_RANGE 0.5 - 10
LINE_WIDTH_GRANULARITY 0.125
POINT_SIZE_RANGE 1 - 189.875
POINT_SIZE_GRANULARITY 0.125
OpenCL Platform NVIDIA CUDA
Platform Vendor NVIDIA Corporation
Platform Version OpenCL 1.2 CUDA 10.1.95
OpenCL Device TITAN RTX
OpenCL Type GPU
Device Version OpenCL 1.2 CUDA
Frequency 1770 MHz
Compute Units 72
Device Address Bits 64
Global Memory 24335 MB
Max Allocation 6083 MB
Global Cache 1152 KB
Max Constant Args 9
Max Constant Size 64 KB
Local Mem Size 48 KB
2D Image Support 32768x32768
3D Image Support 16384x16384x16384
OpenCL Platform Extensions:
cl_khr_global_int32_base_atomics
cl_khr_global_int32_extended_atomics
cl_khr_local_int32_base_atomics
cl_khr_local_int32_extended_atomics
cl_khr_fp64
cl_khr_byte_addressable_store
cl_khr_icd
cl_khr_gl_sharing
cl_nv_compiler_options
cl_nv_device_attribute_query
cl_nv_pragma_unroll
cl_nv_d3d10_sharing
cl_khr_d3d10_sharing
cl_nv_d3d11_sharing
cl_nv_copy_opts
cl_nv_create_buffer
OpenCL Device Extensions:
cl_khr_fp64
cl_khr_icd
cl_khr_gl_sharing
cl_nv_pragma_unroll
cl_nv_d3d10_sharing
cl_nv_d3d11_sharing
cl_nv_copy_opts
cl_nv_create_buffer
ouyeantai
By the way. My scene is just a small scene.(a sphere and three planes with textures). And my render GPU was titan RTX 24G of memory
juanjgon
Sorry, it seems that there is a problem with Octane and the latest NVIDIA driver released a few days ago (the 418.81 build, I think). You are going to need to revert back to an older NVIDIA driver version (for example 417.71) to work with this Octane build.
k3nny
I have repeatable crash caused by applying open subdiv in the spare properties when Cd attribute is being used on the mesh and accessed in the material graph.
Houdini gets to a certain point loading and then disappears.
juanjgon
k3nny wrote:I have repeatable crash caused by applying open subdiv in the spare properties when Cd attribute is being used on the mesh and accessed in the material graph.
Are you talking about the Octane native opensubd feature? I know that there is a bug with this feature in the Octane core that has been fixed for the next build, so probably this the same issue.
zbynekkrulich
Hey Juanjo,
thanks
I put NVLINK to test and it seams that octane crashes when I hit the VRAM capacity of one card - is VRAM pooling one of the features?
I simply created high-poly geo ... do you have any better idea to test if it is working, pls?
thank you
best
Zbynek
ps: I read this viewtopic.php?f=33&t=69896&p=354093&hil ... nk#p354093
MPlay - when I went with higher polycount it crashed
IPR
IPR
octane.log
log
(10.07 KiB) Downloaded 383 times
k3nny
Yes its the octane OpenSubdiv feature.Any idea when this update is going to be released?
Thanks for the prompt reply.
