OctaneRender™ for Blender 2018.1 - 17.2 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Optimized node graph rendering
  • Supported dragging into image feature for world texture
  • Added post processing in render layer
  • Removed legacy livedb
FIXES SINCE LAST RELEASE
  • Fixed memory corruption under some specific resolutions
  • Fixed Transmission input issue in Diffuse Material
  • fixed resharpable mesh vertices error
  • Fixed light mesh update error
  • Fixed probabilistic motion blur update failure
  • Fixed camera move probabilistic render error under motion blur
  • Fixed camera motion blur rendering failure when changing shutter alignment
  • Fixed denoies passes missing error in render layer
  • Fixed the inverted inputs in mix material
  • Fixed compatibility check_update issue
  • Fixed render failure when area light size = 0
  • Fixed misspelling errors
You can read about new features of OctaneRender™ 2018.1 RC1 here:
viewtopic.php?f=33&t=70196
1. OctaneRender™ Server
Windows
Blender Octane Edition - 17.2 (2.79)
Octane Server - 17.2
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v17.2 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v17.2 OSX Autoinstaller
