Carrara's demo plugin
Carrara (Integrated Plugin developed by Sighman)
LittleFisky
I wanted to try Octane in Carrara, and installed demo plugin (2.17.0068),but it's not working. Log says
[13:53:10.582] Started logging on 17.01.19 16:53:10
[13:53:10.582]
[13:53:10.582] Flag Type Value Prefix Description
[13:53:10.582] ------------------------- ------- ---------- ---------- --------------------------------------------------------------------------------
[13:53:10.582] apiChangeMgr release 0 "apiChngMgr" Logs ApiChangeManager::update().
[13:53:10.582] apiNetwork release 0 "apiNetwork" Logs all important calls into ApiNetRenderManager
[13:53:10.582] apiNodeSystem release 0 "apiNodeSys" Logs all write operations in the API node system.
[13:53:10.582] apiProject release 0 "apiProject" Logs all important calls into ApiProjectManager.
[13:53:10.582] apiRender release 0 "apiRender" Logs all important calls into ApiRenderEngine.
[13:53:10.582] cudaProf release 0 "cudaProf" Enables general logging of CUDA profiling.
[13:53:10.582] cudaProfDetail release 0 "cudaProf" Enables logging of single CUDA activity records.
[13:53:10.582] logAppendToFile release 0 "" If enabled, logging will be to the already existing log file appended
[13:53:10.582] logFlags release 1 "" If enabled, all log flags will be dumped during startup
[13:53:10.582] logFlushTime release 0 "" The time (ms) after which the log is flushed. If set to 0, the timer based flush will be disabled.
[13:53:10.582] logForceFlush release 0 "" If enabled, every logged line will be flushed
[13:53:10.582] logJuce release 0 "JUCE" If enabled, JUCE logging will go through the logging framework of Octane
[13:53:10.582] logPrefix release 1 "" If enabled, each log line will have a prefix
[13:53:10.582] logTime release 1 "" If enabled, each log line will have a timestamp
[13:53:10.582] logToDebugConsole release 0 "" If enabled, logging will go to the debug console (Windows only)
[13:53:10.582] logToFile release 0 "" If enabled, logging will go to a log file
[13:53:10.582] logToStdout release 0 "" If enabled, logging will go to standard out
[13:53:10.582] subdivider release 0 "subdivider" logs info about the subdivision process
[13:53:10.582]
[13:53:10.582] OctaneRender version 2.17 (2170000)
[13:53:10.582]
[13:53:33.473] ERROR : device 0: failed to find a CUDA binary matching compute model 6.1
[13:53:33.790] Scene contents: 0 primitives, 1 cameras, 1 lights, 0 master objects, 1 master shaders
[13:54:01.632] Scene contents: 4 primitives, 1 cameras, 1 lights, 4 master objects, 40 master shaders
Is there ANY way to try it for Carrara?
EddyMI3D
Hi LittleFisky,
I assume you have installed OctaneRender 2.17.
a) Does OctanRender run with the demo files?
b) What Graphic Card do you have?
My Rig:
PC with AMD FX 8350 @ 4,00 GHz
Win 7-64
Nvidia GTX 760
Nvidia GTX 970 (only for rendering)
About 6 TB of disk space (768 GB of SSD)
Octane/Octane for Carrara
LittleFisky
EddyMI3D wrote:Hi LittleFisky,
a) how can I check it?
b) Zotac GeForce GTX 1060 6Gb with latest drivers.
DAZ studio's plugin works fine with this video card
EddyMI3D
If you have running a newer version of OctanRender than 2.17 for the Studio plugin, it may not work with the Carrara Demo 2.1.7
My Rig:
Win 7-64
Nvidia GTX 760
LittleFisky
EddyMI3D wrote:If you have running a newer version of OctanRender than 2.17 for the Studio plugin, it may not work with the Carrara Demo 2.1.7
So what can I do about it?
Sighman
I have posted a new demo based on Octane Render 4.02: Octane Render for Carrara DEMO 4.02
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
LittleFisky
This version is working, thank you! Even hairs and foliage are visible in render
Return to “Carrara”
