OctaneRender™ 2018.1 RC1
abstrax
Hi all
Since XB2 we have addressed various issues and finalized the interface for procedural geometry (vectron / SDF). Since this build is more or less feature complete we are releaseing it as release candidate. There will be most likely a couple more releases until we will call it stable and we expect a few more tweaks here and there, but feature-wise that's probably it. Of course, we are already working on the release for the next development cycle.
Reminder: 2018.1 RC1 will only be available for customers with a version 4 license for a limited time. To try 2018.1 RC1 you need to upgrade your version 3 license to a version 4 license. This can be done for free via our web shop: https://render.otoy.com/shop/upgrade.php.
The main change comppared to 2018.1 XB2 is the way how OSL code of procedural geometry returns values: The output value is now of the Octane-specific type _sdf, which is defined as:
// struct for vectron shader networks (used for sdf inputs, and outputs).
struct _sdf
    int   objId;
    int   matId;
    float u;
    float v;
    float dist;
This way vectron objects can provide the necessary information required for shading. Please have a look at this simple example where a vectron node creates a blended union of two input vectron nodes:
sdf-union-material4.orbx
(71.17 KiB) Downloaded 557 times
(EDIT: The original example scene got replaced since there were some issues with it like the one that calus reported.)
For completeness here is the previous example scene updated to the new SDF interface:
Fun_With_Vectron.orbx
(16.02 MiB) Downloaded 897 times
Changes since OctaneRender 2018.1 XB2:
  • Overhauled the way you return data in vectron nodes - see above.
  • Added support for importing / exporting vertex attributes in Alembic files.
  • Improved partial updates of mesh data loaded from Alembic files, by loading only data that is necessary.
  • Improved detection of moving vertices at start and end of animation sequences.
  • Always show bar meter to indicate peer to peer mapping is in being enabled.
  • Worked around an issue with FBX files exported by Maya, which have their SSS sharpness values scales down by a factor of 10 (see viewtopic.php?p=354044#p354044).
  • Fixed incorrect render restart if the noise pass gets enabled / disabled when adaptive sampling or the denoiser is enabled.
  • Fixed loading of the opacity channel of FBX materials .
  • Fixed loading of normals and UV coordinated (see viewtopic.php?p=353284#p353284).
  • Fixed crash in scene graph update when an empty group node is being used, fixing the Xparticles scene provided in viewtopic.php?f=86&t=70006.
  • Fixed bug that caused geometry to disappear or to render only partially on some frames of animations.
  • Fixed rendering of the third UV coordinate set.
  • OSL: Improved error handling in certain situations.
Downloads for users with a regular license
OctaneRender for Windows (installer)
OctaneRender for Windows (zip)
OctaneRender for Mac OS
OctaneRender for Linux
Downloads for users with a Studio subscription license
OctaneRender Studio for Windows (installer)
OctaneRender Studio for Windows (zip)
OctaneRender Studio for Mac OS
OctaneRender Studio for Linux
Downloads for users with a Creator subscription license
Photoshop Compositing Extension download
You can download and install the current Photoshop Compositing Extension (1.1.0) either via the Adobe Exchange platform or you can download it from the link below and manually install it.
Windows and Mac OS X
Photoshop Compositing Extension (v1.1.0) (ZXP archive)
Happy rendering and a happy new year to you all :)
Your OTOY Team
calus
This issue is not specific to Maya FBX : I confirmed this by testing with C4d fbx export, exact same wrong result in Octane than with Maya FBX.
> It just seems that Subdivision Surface Sharpness values (crease) are stored in FBX format with a different unit than what Octane naively expects (1 internal FBX crease unit = 10 Octane crease unit )
Please remove specific workaround for Maya FBX and make it a global fix.
Pascal ANDRE
PolderAnimation
Octane is moving fast. Very nice. Thanks for the update!
Win 11 | Dual RTX 5090 | AMD Ryzen 9 9950X| 192GB
ramone163
Are you going to fix this? When the camera is inside of volumetric light.
GPU: 2x4090; 3ds max;
Behance portfolio; Handmadefont.com;
Notiusweb
I already can report that several ABC files I have are not importing into RC1, but were importing fine into XB2.
Issues consist of Octane freezing during AI Cache, and missing geometry in the ABC file.
In each case if left on, ABC files in Octane RC1 will cause GPUs to disconnect and driver reset.
DPC Latency shows no spike, and # GPUs is not a factor either. Seems that RC1 just has a very very rough time with ABC files.
FBXs on other hand load in great, Opacity fix is very nice! I find that Metallic map and roughness is not imported, just are imported as Black (or "0") like Opacity was.
No big deal, we can tweak in scene no issue, just wondering if this this a parameter stored in the FBX file that could be read by Octane.
Really cool, looking forward to Substrates, Upscaling, and Anime Kernel....
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
calus
The sdf-union-material.orbx example have a mistake In the unionRound function, swaping the SDF input in the result:
a.dist - b.dist should be b.dist - a.dist
sdf-union-material2.orbx
(72.19 KiB) Downloaded 429 times
Pascal ANDRE
Notiusweb
Finding ABC files "AI caching" causing also my Windows 10 itself to freeze and stutter as the GPU driver battles to stay connected. When ultimately then disconnects, screen goes black and then takes a minute to come back.
Does not happen in XB2.
Changes with handling of ABC files is likely connected to issue I see I am thinking.
Plugs: Enterprise
PolderAnimation
There are 'colour vertex attribute' and 'greyscale vertex attribute' nodes. You can not use a vector attribute in a greyscale node (make sense).
But can we have it that if you put .x .y or .z after the string input you can use that float channel of the vector in a ' greyscale vertex attribute' node?
For example you have a vector Cd for your vertex colors. But if you want to use 1 channel you can use Cd.x in a 'greyscale vertex attribute' node and only use the red channel.
That would be great.
bagel
Hey not sure if this was addressed or not in this version, but in XB2, deep EXRs came out corrupted and the option to export a deep EXR was removed or moved to the passes export window. I do a lot of deep compositing so I rely on this feature which is why it cropped up for me.
I'll test with RC1 and see if the bug still persists.
Thanks for all you hard work, especially over the holidays, no less!
PolderAnimation
I keep coming with requests but just trying to make octane better :).
It would be nice to have the option to make reference copys of placement nodes. So when you adjust one all of the other will adjust too.
Just an idea. Cheers,
