Hello all!
Does anyone know where to set octane to only use one specific gpu instead of all gpu's from within the Houdini UI?
Is it even possible?
Br,
Hamp
Only use certain GPU?
Yes, you can configure the GPUs options in the plugin options panel, GPUs tab. In this tab, you can not only enable the GPUs that will be used for rendering, but also their priority and GPUs are enabled for tonemaping and for denoising.
https://docs.otoy.com/HoudiniH/HoudiniP ... ptions.htm
From any script or from the non-GUI tools like hython, you can also configure the GPUs using the "Octane_setGPU" HScript command.
