What is Octane doing when it says 'copying document'? I can't render a file I was rendering quite happily all week. It just hangs c4d when 'copying document'. I've tried trashing Octane and c4d prefs, but didn't work.
OSX Octane 4.1.1 c4d r20
copying document...
It's creating a copy of the current document. You do nothing about a fix. Problem should be a different thing if you render this file before. Maybe you changed somethings in scene. Delete some parts of scene and try again until find the problem.mitchino wrote:What is Octane doing when it says 'copying document'? I can't render a file I was rendering quite happily all week. It just hangs c4d when 'copying document'. I've tried trashing Octane and c4d prefs, but didn't work.
What It means, start a blank doc?mitchino wrote:It happens a lot. Anyway, I find that if I start c4d with a blank document, then open the live viewer and get it running, then open the problem document, it all works.
It would help if you describe the exact steps. Or show it by a video. Because I never seen this.mitchino wrote:It happens a lot. Anyway, I find that if I start c4d with a blank document, then open the live viewer and get it running, then open the problem document, it all works.
exact steps to give problem:
start c4d > open document > start live viewer > octane says 'copying document' then hangs
exact steps to avoid problem:
start c4d > start live viewer > open document > works normally
this problem doesn't always happen - but it does quite a lot
PM sent!
