Octane materials not working on emitter
- alecmaassen
What are you rendering? Sphere particles or some other type of voxel? You should be able to put a material directly on the emitter or sphere or whatever object you're using as the particle
- alecmaassen
you need to put your sphere inside of the geometry box in the object tag. I've set it up for you in the fixed file attached. you dont need an object tag on the sphere itself either, btw.
let me know if you need more help!
- Attachments
- test particles_fixed.zip
- (70.17 KiB) Downloaded 191 times
Unoptimized way to use particles. At least use render_instances or object tag with particles section.spliffiam_1 wrote:I managed to do it by just ticking this box
alecmaassen's usage is good but keeping sphere under the emitter that will cause double geometry in Picture Viewer.spliffiam_1 wrote:Oh really? So is the way that the other guy said better?
Here's perfect usage of particles. Please check manual for object tag and InstanceColor.
- Attachments
- test particles-aoktar.rar
- (66.55 KiB) Downloaded 248 times
- alecmaassen
ahhhh yes aoktar is right, you dont need to be under the emitter.
