Mesh to vectron
tschwenke
How can I convert a complex mesh into a vectron node in XB1?
Best wishes,
Thomas
http://www.thomas-schwenke.me
Houdini 20.5 || Win11 || i7 + RTX3080
haze
Currently you need to convert the mesh into an SDF with a tool like Houdini, then export to VDB.
Any VDB levelset surface can be used with vectron.
ramone163
haze wrote:Currently you need to convert the mesh into an SDF with a tool like Houdini, then export to VDB.
Do you have plans to add your own "mesh to VDB converter" to Octane?
GPU: 2x4090; 3ds max;
Behance portfolio; Handmadefont.com;
haze
We're planning to make meshes work as part of vectron, but it is a difficult problem to solve. Plan B would be a mesh to vdb levelset converter yes. No guarantees as yet.
rrbarb
I hope a level set convertor makes the cut.
./rrb
rohandalvi
Just adding to this.
A slightly different request for vectron.
Would it be possible to render a vectron object with a volume shader. So if I take a vdb sphere , covert to vectron and add noise displacement. Then I can use a volume shader to render it as clouds. It would be nice to have that as an option.
Regards
Rohan
