Transmission inverted ?
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
rifat
Hey,
I try to do transmission on a paper.
but the transmission is only happening in the dark area of the diffuse map. which it should be inverted.
If I invert the diffuse the transmission is correct but then diffuse is wrong. as the image attached.
https://drive.google.com/file/d/1y4Vvrf ... sp=sharing
instead if inverting the Diffuse texture, reduce its Power value at something like 0.5:
ciao Beppe
rifat
Thanks so much!
:D
Return to “Bug Reports”
