Hi Guys, really need help on this one.
I think what I want to use is SSS. Alas I haven't used this feature in Octane yet.
I have a flat surface that is used in some signage solutions where I live, and behind that surface are thousands of LED's. The effect allows for the material to be lit up from behind and create the illusion of movement on the surface, but it's only the lights behind the surface changing color. I kind of have the look with a specular material but I can not put a BMP on a diffuse channel, which I need.
Can anybody help?
SSS on a flat surface
Specular with roughness to diffuse the lights (presume this is the look you want) and mix it with a glossy to add opacity if desired?
Or try diffuse with transmission and again. mixed with glossy to get spec reflections
Win 10. Threadripper 1920X 32gb Ram GTX 1080Ti GTX 980Ti 2xGTX 780
http://ajdesignstudio.co.nz/
