Clear window
pedromod
Hi Im not sure if Im doing anythng wrong here but Im just testing exporting a simple cube from max to Octane and all I see is a clear window with nothing in it when octane starts.
Please help not sure what Im doing wrong.
Windows 7
Max 2010
Quadcore 2.83
8Gb Ram
Max Window
Max Window
Screen Print.
Screen Print.
pedromod
Any suggestion anyone??????????????????????????????
I havent been able to use the program because of this......
Please guys.....
abstrax
It looks to me that the camera is completely misplaced or. What are the camera node settings (position/target/up vector? Could you post a screen shot of the camera node?
Marcus
pedromod
Hi adstrax...
ohh men thank for responding.
The camera seems to automatically set and it seems right to me.
btw. Im using max2octane_1.022h version. Have tried max2octane_1.022f and max2octane_1.022g
and Octane version 1.0 beta2,46
kubo
check the units, (in max there is 2 settings for that global and local or something the like) and check the obj export default values <none> against this http://www.refractivesoftware.com/forum ... f=21&t=362 doing a manual export, the script uses the default values stored in the internal max exporter stored under <none> so if by chance you've modified those it could be messing (like having a diferent scale value from 1.0)
pedromod
WAAAOOO
all i need to do was turn Octane settingd to Meters...
Thanks alot
now happpyyyy
Return to “Autodesk 3Ds Max”
