Exporting Model from Octane to 3ds Max?
SamuelAB
Our team made a model in Modo and added the textures in Octane Standalone.
I need to take this mode with the materials, split it into smaller pieces and reduce it's geometry in 3ds Max, so I can make an optimized VR model in Unity. Is it possible to export an Octane model into an FBX or similar format so I can open it in 3ds Max and edit it using the applied materials?
paride4331
Hi SamuelAB,
you can save you Octane material in LocalDB, then import them in 3dsMax.
viewtopic.php?f=27&t=64724&p=328943&hil ... DB#p329088
Unpacking .orbx, file you can find .obj internally; alternately import .fbx or .obj from Modo
Regards
Paride
SamuelAB
Awesome, thanks I will look into this.
Do you know if I can make these Unity materials somehow?
paride4331
Hi SamuelAB,
you can export Octane material to .Orbx, then import it in Unity.
https://docs.otoy.com/UnityH/UnityManua ... Format.htm
Regards
Paride
SamuelAB
Awesome, thanks!
