So at the risk of listing a bug that everybody is familiar with, I feel like I should at least put this out there in case it helps with debugging.
I have two 980TIs,
Win 10, latest Geforce, latest Cuda.
With heavier scenes, and even with CPU checked sometimes, I still get an occasional GPU Failure that I can't recover from. Closing photoshop and anything else won't fix the problem. I'd have to restart 3dsmax and THEN it works. Isn't there a way to 'fix' or 'reset' the GPUs without having to restart 3dsmax?
GPU Failure
- paride4331
Hi dartfrog,
try to reduce Parallel sample
try to check "clear node cache when render" in Octane global setting > Trouble shooting.
Regards
Paride
Regards
Paride
- paride4331
Hi DartFrog,
is this issue using Octane 3.08.x and cpu memory option?
Regards
Paride
Regards
Paride
4.00 RC4 - 6.07
Cuda v9.2
Geforce 416.16
i JUST upgraded to that Geforce driver and so far it's been behaving. I'll keep this current setup for a few days and see if I still get the same issue. I keep jumping around to different projects so when I'm in a scene that gives me trouble, I'll know for sure if it's an issue still.
Thanks for the prompt feedback.
Cuda v9.2
Geforce 416.16
Yes - this is still an issue.
1- It'll render fine
2 - Change something small like saturation level in a material
3 - GPU Failure
4 - Can't render any more without failure
5 - Restart max
If I close the render window, make my change, and re-launch, it renders.
This isn't with all scenes, just a handful.
3 - GPU Failure
5 - Restart max
- paride4331
Hi DartFrog,
using BRDF > GGX?
Regards
Paride
using BRDF > GGX?
Regards
Paride
- paride4331
Hi Dartfrog,
We had GPU faillure in RC2 SDK switching to GGX and slidering.
Is this your case too?
Regards
Paride
Regards
Paride
