I cannot install the octane demo for rhino 6 ....
anyone encounters the same problem?
The error message says
Rhino Plug-in Error
"Unable to load OctaneRenderForRhino.rhp plug-in:initialization failed. "
I have uninstalled Rhino 5 from my laptop, and there should be nothing puzzling for the installer.
Anything I can do about this bug ?
[img][/img]
						Cannot install the octane demo for rhino 6
Can you post a screenshot of the "Details" screen pls?
What SR of Rhino6 do you have installed pls?
The plugin was built using Rhino6 SR8, so the installer should work.  If it will not install, then there is an issue with your Rhino6 installation.  May I suggest reinstalling Rhino6, or submitting a bug report to McNeel.
McNeel have got back to me on this issue, and suggest installing Rhino6 SR9, since it contains some bug fixes in the installer code which may resolve this issue.
Hi Paul
Thanks for the help. although installing SR9 didn't work I figured out a way in which it did.
I uninstalled rhino six and then manually uninstalled the footprint it left behind (folders in App data & Program data. I also deleted the rhino 6 registry keys)
After i did this I installed rhino 6 and octane plug in and it worked fine
Win7 pro 64 / i7 4930 3.4 6core / 2x gtx 680 4gb / 32gb DDR3
