Some issues with image sequences
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
pegot
(1) Image sequences are not visible when scrubbing the timeline in Octane Blender. They work fine when rendering the animation, but you can not see them in preview mode.
Stand Alone does allow you to scrub the timeline and preview any image sequences assigned to textures.
Of course, there is the offset value and moving that does show the image sequence in the preview. Unfortunately, that does not help if the material uses multiple animated textures (for instance, a material with bump, normal, roughness, metallic maps that must be animated in unison). The offset slider has no input pin, so it is not currently possible to attach a value node to hook into multiple textures at once and move their offsets together.
(2) Image sequences in Octane Blender exported to ORBX do not show up in Stand Alone. Nor is there a timeline in the exported ORBX. Additionally, it is not possible to manually modify the nodes once in SA since the "Add Files" button is grayed out. One needs to use a complete new image texture node and re-import all files.
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
DrawFun
Hi pegot,
Thanks for your report. I will look into it.
DrawFun
DrawFun
Hi pegot,
It will be fixed in 16.2.6.
DrawFun
Return to “Bug Reports”
