Render over 10k pixels not saving
cristiangiro
Hello,
when i render a single image that has a side of 10000 pixels, the file with passes is never saved, i have to go and save them manually one by one.
any idea why?
what about the available RAM in your system?
If not enough, you can use the Tiled Camera rig with lower resolution, and compose back the frame in PS, but you need to remove vighetting and post effect.
ciao Beppe
cristiangiro
Ciao Beppe,
i have 64 gb of ram in my system, maybe they ar enot enough
what's the tiled camera rig? never heard of it, sounds interesting
Please make a simple scene and try same. Define is it specific to a scene or general problem on you.
it depends from free RAM while saving, try to ckeck the consumption in Task Manager.
About the Tiled camera, open c4d Content Browser, and navigate to Presets/Prime/Presets/Tools & Helpers:
viewtopic.php?f=85&t=68503
Which exacy version of plugin have you installed?
You can check it in the first line of the Console window (Shift+F10).
ciao Beppe
cristiangiro
it is general, i try to work with that size on all projects
of course they also are full of elements
with the tiled camera rig seem to work on a simple project, i'm going to try on a heavier file
thanks
