Rotating HDRI environment in 16.x is still slower and jerky compared to previous versions like 15.2.6. There is constant information "Updating shaders" when rotation is performed.
15.x.x and previous was silky smooth.
16.2.2 - HDRI environment rotation stutters
C. RAM Capacity (i.e. 6 GB)
System – Windows 11
System – Windows 11
With bigger HDRI maps like 8k or more the rendering pauses for a second or more until "Updating shaders" finishes.
System – Windows 11
System – Windows 11
Hi J.C,
We've fixed an environment hdri update issue in 16.2.2. And I've tested it in internal build 16.2.3 for both windows and mac but fail to reproduce this case.
Could you please give a bit more details about this issue? Thanks.
DrawFun
DrawFun
Hi DrawFun,
Download high resolution environment file preferably 8k or 16k.
https://hdrihaven.com/hdri/?h=portland_landing_pad
Set it as an environment texture. Add or create some objects, preferably 10 or more with different materials.
Try to rotate the environment. There will be constant "Updating shaders" and freezes after finishing rotation or changing map parameters.
System – Windows 11
System – Windows 11
Here is the screencast from Blender plugin and standalone app. It shows the environment update with 8k file and 10 objects and materials. Everything updates after 10 seconds. The same scene updates instantly in Standalone app.
- Attachments
- looong update.mp4
- Update in Standalone
- (4.84 MiB) Downloaded 2385 times
- instant update.mp4
- Update in plugin
- (34.41 MiB) Downloaded 2392 times
System – Windows 11
System – Windows 11
I've found the reason of such behaviour. When the texture colour depth is set to "Automatic" is causes the freezes. Setting it to 16bit or 32bit makes it smooth again.
In 15.2.6 it was ok with "automatic"
- Attachments
- instant update plugin.mp4
- 15.2.6 with "automatic" and no freezes
- (12.45 MiB) Downloaded 2390 times
System – Windows 11
System – Windows 11
Yes, the fix for automatic is working.
System – Windows 11
System – Windows 11
