Crash when opening file from R18 in R19
HazrulIdzwan
Hello,
We're having this issue of C4D R19 crashing when opening files from R18,
Bug report is attached. In the scene we are using Forester with Octane Scatter. Will scattering with unconnected vertices cause this issue?
_BugReport.txt
(391.33 KiB) Downloaded 258 times
Octane 3.08 on Win 10 Pro 64bit
2 x GTX 1080 TI driver version 24.21.13.9907
Thank you for your time,
Best Regards,
HazrulIdzwan
Ciao Beppe,
I am on 3.08.3 yes.
Which version of forester?
Could you please share a scene?
HazrulIdzwan
Forester version is 1.1.0c
I will dm you the link to the file @aoktar,
Thank you!
HazrulIdzwan
Hi all,
@aoktar
@3DQUAKERS
Just linking the file here in case someone else has any ideas
https://drive.google.com/open?id=1ha_0n ... vC1qzPrTjx
Seems to involve Forester Objects using Octane Scatter and a reference mesh of unconnected vertices.
Kind Regards!
It's crashing on scatter object's codes. There's a distribution object without any polygons and crashes. I'm fixing this problem.
Run C4D without Octane and delete this object and save your scene. Later it will not crash.
HazrulIdzwan
aoktar wrote:It's crashing on scatter object's codes. There's a distribution object without any polygons and crashes. I'm fixing this problem.
Thank You for the confirmation aoktar! Unfortunately most of our distribution meshes for this project are made by cloning stray vertices. and there are multiple distribution meshes in several scenes.
Is there an ETA for the fix or do you think we should fill the vertex "cloud" with polygons?
Best Regards,
Best Regards,
I assume that's fixed. I'll send you a test version. Which version do you need?
HazrulIdzwan
Best Regards,
Hello aoktar,
Thank you!
Im working on R19 so 3.08.3 please?
Will this fix be in V4 as well?
