OctaneRender™ for Blender 4.0 XB4 - 16.2 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • New v4 XB4 features (please check at viewtopic.php?f=33&t=68283).
  • Support universal material
  • support light linking
    • Global light exclusion: "Render-Octane Kernal-Light"
    • Light linking for object: "Data-Octane Properties-Light pass mask"
  • Support new AI light and settings
  • Support UDIM
    • "Node graph-Octane Texture-Octane Image Tile Tex"
    • How to use:
      • Select the a uv texture in the target folder
      • Change the file pattern as the definition in SA
        • e.g. %uu-%vv.jpg with options(2*2 size, 2 digits) => 1u-1v.jpg, 1u-2v.jpg, 2u-1v.jpg, 2u-2v.jpg)
    • You can check current UV list in the console("Windows-Toggle System Console")
    • Support new light passes in v4 XB4(direct/indirect(ambient light, sunlight, light pass 1-8))
    • New features and refactored systems(these are included in 16.1).
    • New Render Pass System(including all passes and optinos in v4 xb4 SA)
      • New Passes: refract filter, transmission filter, postprocess, all lighting passes(ambient light, sunlight, light pass 1~8), position, texture tangent, motion vector, light pass id, render layer id, render layer mask, wireframe, object layer color, Baking Group ID, all Material Passes (opacity, roughness, ior, diffuse filter, reflection filter, refraction filter, transmission filter)
      • New Options: include environment, uv coordinate selection
      • Fix bugs: use rgba color for object id and material id passes
    • support scatter conversion with instance ids for duplication/array modifier/particle system (Please check samples in ScatterFeatures, same as what I sent before)
      • please note that the array modifier will break instances by default. To solve this, please introduce duplication while using array modifier
    • support node group.
      • now node group input value can be resolved independently in different materials. (Please check "node_group(made_by_JC).blend")
      FIXES SINCE LAST RELEASE
      • Add AI Light update and AI Light strength
      • Report warning when rendering denoise passes without enabling denoise
      • Add point type to draw bounds as points
      • Fix bug: Blend Angle option in the Triplanar Mapping node is not working
      You can read about new features of OctaneRender™ 4.0 XB4 here:
      1. OctaneRender™ Server
      Windows
      Blender Octane Edition - 16.2.0 (2.79)
      Octane Server - 16.2
      Linux
      Installation:
      $ OctaneServer &
      DOWNLOAD
      Blender Octane Edition - v16.2 Linux
      OSX
      Installation:
      - Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
      DOWNLOAD
      Autoinstaller: Blender Octane Edition - v16.2.0 OSX Autoinstaller
      ZIP archive: Blender Octane Edition - v16.2.0 OSX ZIP
DrawFun
Add some demos in the post.
16.2 Samples.7z
(9.08 MiB) Downloaded 354 times
