Production render longer than live preview.
Kid0k
Hello. Can you help me with my problem.
The scene in the live preview is rendered very quickly. 4 minutes per frame.
Once you post production renders, the time increases to 30 minutes per frame.
3ds max 2018, 2 Gtx 1080ti.
Thanks.
promity
For this it is required to see your settings.
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
paride4331
Hi Kid0k,
it sounds very strange, as promity said, more information is needed to understand what happens.
Regards
Paride
Kid0k
There is a very complicated scene. built entirely on heavy alembic files. (all animations baked)
The preview in half resolution rendered, the first frame was considered to be long, 15 minutes, but the second-third and all the subsequent ones were rendered quickly (2 min per frame).
Increased the resolution, everything stopped working, 30 minutes per frame. In live preview 4 min per frame.
The drivers are new. 2 cards. Gtx 1080 and Gtx 1080
settings
settings
paride4331
Hi Kid0k,
try to set movable proxy only for objects are moving.
Regards
Paride
Kid0k
paride4331 wrote:Hi Kid0k,
Regards
Paride
Nothing has changed. all the same on the render takes 3-4 times longer than in the live preview.
Scene is heavy, but is updated very quickly.
coilbook
Regards
Paride
i think live preview does not count time when it is processing the scene while live window is being opened only render time
paride4331
Hi Kid0k,
what coilbook said could be the answer. Perhaps you are rendering many render layers. They take time too.
Regards
Paride
Return to “Autodesk 3Ds Max”
