I need to translate a bunch of RGB color to fit the rgb4k_map.ppm so i'm looking for the formula.
Can you help me ?
Instance rgb map
This translation is a bit complex. I can send you the C++ function used to encode the RGB to UV map, but why do you need it? The plugin should be able to use any RGB Cd attribute to get the final color in the rgb4k_map.ppm texture.
