Instance rgb map
Forums: Instance rgb map
Houdini Integrated Plugin
Instance rgb map
Postby Issa » Thu Jul 26, 2018 10:23 am
Issa Thu Jul 26, 2018 10:23 am
I need to translate a bunch of RGB color to fit the rgb4k_map.ppm so i'm looking for the formula.
Can you help me ?
Issa
Re: Instance rgb map
Postby juanjgon » Thu Jul 26, 2018 6:13 pm
juanjgon Thu Jul 26, 2018 6:13 pm
This translation is a bit complex. I can send you the C++ function used to encode the RGB to UV map, but why do you need it? The plugin should be able to use any RGB Cd attribute to get the final color in the rgb4k_map.ppm texture.
juanjgon
Postby Issa » Thu Jul 26, 2018 7:32 pm
Issa Thu Jul 26, 2018 7:32 pm
Hi juanjgon,
I try to optimize computation time to get photogrammetric point cloud ready for rendering. It time consuming to convert millions points in houdini.
This can realy help me :)
Issa
Postby juanjgon » Fri Jul 27, 2018 8:13 am
juanjgon Fri Jul 27, 2018 8:13 am
Ok. I've sent you by pm the code used by the plugin. Hope it helps.
juanjgon
Return to Houdini
Fri Apr 19, 2024 4:18 am [ UTC ]
