1000 character on a bike
LightwaveGuru
snip lwguru
http://www.neotek.laboratories.de or http://www.youtube.com/c/Lightwaveguru or http://www.facebook.com/safarifx 4x Titan X 12 GB watercooled / 6x 2080 ti air cooled / 2x 980 ti watercooled
BorderLine
Good test ! And with "Tour de France" ! Go to Sagan !
LightwaveGuru
BorderLine wrote:Good test ! And with "Tour de France" ! Go to Sagan !
final render than tomorrow...
snip lwguru
vpii
I wish we could get instance animation offset like we use to in HD instance plugin. I wish he would update it of someone develop a new workflow.
LightwaveGuru
vpii wrote:I wish we could get instance animation offset like we use to in HD instance plugin. I wish he would update it of someone develop a new workflow.
you can it do as work around also with the lw instancer system. i show it as next.
here so long some better renders.
snip lwguru
pixym
Marvelous test…
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10
Net render : MB Asus Pro WS W790E-SAGE SE - XEON - 128GB - 2 x RTX 3090 - 3 x RTX 2080TI
LightwaveGuru
pixym wrote:Marvelous test…
:) many thanks.
snip lwguru
3dreamstudios
snip lwguru
Very nice, hoping you can share the "hack" to get offsets with LW Native instancing...this king of demo you show HAS to have such a thing, or it throws it off tremendously. Otherwise very nicely done!
Would even be better with offset on speed, allowing some to go a bit faster than others...and then flocking so they dodge each other through the race! lol.
LightwaveGuru
yes!
the hack is in the end not a hack and is realy simple. (reason > in that way work the lw instancer) you need for that only a second or some variations from the start point from the animated cycle loop from the character + hirarchy with the bike.
so load the character and the bike set up in a seperate scene and replace the character with a copy from them and set all animated keyframes from the bike -10 or +10 frames. (or similar)
Than load that set up with load item from scene in the scene, go to the instancer system and copy from there all data from the original. create than a second instancer, load there your copied set up in and copy the data from the first instancer.(instancer > edit > copy settings)
than you need only to change the offset from your xyz parameter (position from your instances) and you gad it! (for change the speed for example animate the offset parameter for splines in the new instancer new/different!) so thats the way to do it with hirarchy instancing.
if you have a simple solo object you can go nother way. for that you can simple use the motion path for instancing and create there a offset. (much more simple)
so this here is only for instancing pre:animated "hirarchies" with automation (with follower plug ins or with expressions etc.pp) and offset/variate later the different instance hirarchys.
hope it helps.
snip lwguru
vpii
Interesting. I will try this. I was thinking maybe you would bake as MDD then off set from that?
Return to “Lightwave 3D”
