VDB FROM FUMEFX 5.0
wrapthereal66
Hello i recently update to fumefx 5 , and there is a lot of glitch with octane about the vdb , sometime its show up , sometime vanish , i don't understand why !
i attach you a exemple of vdb if you want to test !
hope you gonna fix this ! :)
CHEERS !
spline_pp_0036.rar
(1.49 MiB) Downloaded 416 times
wrapthereal66
edit : its not a probleme from the vdb , because i can render the vdb on octane for 3dsmax ! but not on cinema4d !
There should not be any differences! Plugins just define the parameters for vdb, not render it by self. Cannot see your vdb example!
wrapthereal66
edit : i've upload the vdb file !
wrapthereal66
also you say all the plugin are the same ?
for now 1 years my 3dsmax can open vdb from fumefx and find all the channel like temperature etc...
on cinema 4d there is just the velocity ! i can't import other channel ! so yes there is some glitch about managing channel
wrapthereal66
quick reminder , i'm not alone with this problem :
viewtopic.php?f=25&t=55050
As i said that, plugins are using same core. Not sure how did you loaded this vdb and rendered in 3dsmax with Octane!!! As i could that it's not having a compatible grid with Octane.
wrapthereal66
yes ... really strange this is the octane view with exact same vdb ! work really well ! and its a really common problem i have with vdb ! all my fire is rendered with 3dsmax version of octane because the c4d one don"t find the channel !
wrapthereal66
have you any idea ? because its a real problem for me !
wrapthereal66 wrote:have you any idea ? because its a real problem for me !
I can see smoke channel in plugin but not any visible volume in renderer. What it's very strange that i can see volume if I export current scene to standalone. I'll investigate more!
