OctaneRender™ for Blender 3.08 - 15.2.5 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Add sheen roughness for metal/glossy materials
  • Add a button for emptying GPU
  • Add user preference to empty GPU after render automatically
  • Use enum values for displacement and falloff nodes
  • Do not reload scene when turn on/off camera imager
  • Support larger max width for nodes
  • Support back compatibility for transmission color connection in specular material
  • Support back compatibility for projection mode
  • Support back compatibility for camera imager
  • Hide legacy sockets in surface panels
FIXES SINCE LAST RELEASE
  • Fix the livedb crash of gradient texture
  • Fix the livedb crash when updating and drawing node tree at the same time
  • Fix camera imager UI grey out issue
  • Fix medium node connection failure in specular materials
You can read about new features of OctaneRender™ 3.08 here:
viewtopic.php?f=33&t=63219
1. OctaneRender™ Server
Windows
Blender Octane Edition - 15.2.5 (2.79)
Octane Server - 15.2.5
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v15.2.5 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v15.2.5 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v15.2.5 OSX ZIP
