CUDA error 700
theeddyadams
Recently updated Windows 10 and NVIDIA drivers and am now getting regular crashes. I am able to use Octane for a while, but it seems to crash when the camera is Panoramic and stereo is set to Over-under.
Windows 10 Pro - 1803 - build 17134.137
NVIDIA - 398.36
Cinema 4D - R19.053
OctaneRender 3.08.1-R2
CUDA error 700 on device 1: an illegal memory access was encountered
-> kernel synchronization failed
CUDA error 700 on device 0: an illegal memory access was encountered
-> failed to allocate device memory
device 0: failed to allocate post-proc buffers
Project download link - https://drive.google.com/open?id=17lZYl ... qZzdoCVxwF
Thanks!
it’s probably Nvidia drivers related.
Try to use DDU to completely remove the installed Nvidia drivers:
http://www.guru3d.com/files-details/dis ... nload.html
Then try to install 391.35 Nvidia drivers:
http://www.nvidia.com/download/driverRe ... 2845/en-us
ciao Beppe
theeddyadams
Thanks Beppe! I'll give that a shot.
volatilecycle
Thank you for your advice with this Beppe, it fixed my same cuda 700 error.
I had the most up to date drivers installed - 418.91 but this caused octane to have cuda 700 error. You advice of installing driver 391.35 fixed it.
How does everybody know what driver version to use?
Is it best that I stay on driver 391.35 do you think?
Thanks!
this is an old discussion, now the more stable drivers are 417.22/417.71, unfortunately we have discovered that Nvidia 418.81/418.91 drivers are not compatible with OctaneRender:
viewtopic.php?f=7&t=70578
ciao Beppe
volatilecycle
Thank you for the info Beppe!
