Animated texture
Moderator: ChrisHekman
This is not possible at the moment. We're working with Unity on support on getting signals on texture animations. Motion blur is a missing feature, which I'll need to discuss with Octane core devs on how to get that working from within Unity.
- Rick
Hi there, any updates on this since the last post. ¿Is it currently possible at least, to render static objects with motion blur by providing some type of motion vector or main direction of movement?
Thanks.
Thanks.
- ChrisHekman
Atm, not directly from within unity. What you can do is to record to ORBX with the PBR Recorder. And then load that orbx into standalone and render it out there. Then it should have motion blur, as the the recorder calculates the motion vectors when exporting to orbx.jalley wrote:Hi there, any updates on this since the last post. ¿Is it currently possible at least, to render static objects with motion blur by providing some type of motion vector or main direction of movement?
Thanks.
If you dont have standalone, you could reimport the orbx as a proxy into Octane for Unity, and then render it out to png/exr using the PBR Recorder.
