Failed to load octane.dll (C:\Users\sandeep\AppData\Local\Octane\Unity\2018.1.0f2_1.1.1.1314_T1\octane.dll). Errorcode: 577
UnityEngine.Debug:LogError(Object)
Octane.DynamicLibrary:Load()
Octane.PluginDllLoader:LoadLibraries()
OctaneUnity.PluginController:Init()
OctaneUnity.PreferenceWindow:OnGUI()
UnityEngine.GUIUtility:ProcessEvent(Int32, IntPtr)
Moderator: ChrisHekman
I did but now i am getting error code 577 and 126Xhed wrote:Can you try upgrading to NVIDA CUDA Toolkit 9.2, that should fix the issue.
Failed to load OctaneUnity.dll (C:\Users\sandeep\AppData\Local\Octane\Unity\2018.1.0f2_1.1.1.1314_T1\OctaneUnity.dll). Errorcode: 126
Could you verify that the dll has properly been installed to
C:\Users\sandeep\AppData\Local\Octane\Unity\2018.1.0f2_1.1.1.1314_T1\, while I look into the issue? And could you also check which other files are present there? Does the issue persist after restarting Unity?- Rick
It persists even after restart. Files present are octane.dat,octane.dll, octaneunity.dll,libfxdsk.dl, cudnn64_7.dll, octaneunitypackage.Xhed wrote:Could you verify that the dll has properly been installed toC:\Users\sandeep\AppData\Local\Octane\Unity\2018.1.0f2_1.1.1.1314_T1\, while I look into the issue? And could you also check which other files are present there? Does the issue persist after restarting Unity?
It used to work for me in previous version,problem started after updating to latest version
- ChrisHekman
577 - Damaged or improperly signed file/executablebrolly234 wrote:Any work around for this problem??
127 - Means a dependency is missing
Both indicate something went wrong with an installation, or files are missing. The latest Octane version as new features that require the latest drivers.
- Remove the folder:
C:\Users\sandeep\AppData\Local\Octane\Unity\2018.1.0f2_1.1.1.1314_T1\. (You will be promted by a reinstall when you open your OctaneUnity project)- Re-install your nvidia drivers
