Failed to load octane.dll
Unity Integrated Plugin (Integrated Plugin maintained by OTOY)
Moderator: ChrisHekman
brolly234
Failed to load octane.dll (C:\Users\sandeep\AppData\Local\Octane\Unity\2018.1.0f2_1.1.1.1314_T1\octane.dll). Errorcode: 577
UnityEngine.Debug:LogError(Object)
Octane.DynamicLibrary:Load()
Octane.PluginDllLoader:LoadLibraries()
OctaneUnity.PluginController:Init()
OctaneUnity.PreferenceWindow:OnGUI()
UnityEngine.GUIUtility:ProcessEvent(Int32, IntPtr)
Xhed
Can you try upgrading to NVIDA CUDA Toolkit 9.2, that should fix the issue.
- Rick
brolly234
Xhed wrote:Can you try upgrading to NVIDA CUDA Toolkit 9.2, that should fix the issue.
I did but now i am getting error code 577 and 126
Failed to load OctaneUnity.dll (C:\Users\sandeep\AppData\Local\Octane\Unity\2018.1.0f2_1.1.1.1314_T1\OctaneUnity.dll). Errorcode: 126
Toridan
I had the error with ErrorCode: 126 when I updated to OctaneUnity 1.1.1.1341 and when I closed the Unity Project and opened again it disappeared.
Maybe this is your case too.
Best of luck!
Xhed
Could you verify that the dll has properly been installed to C:\Users\sandeep\AppData\Local\Octane\Unity\2018.1.0f2_1.1.1.1314_T1\, while I look into the issue? And could you also check which other files are present there? Does the issue persist after restarting Unity?
- Rick
brolly234
Xhed wrote:Could you verify that the dll has properly been installed to C:\Users\sandeep\AppData\Local\Octane\Unity\2018.1.0f2_1.1.1.1314_T1\, while I look into the issue? And could you also check which other files are present there? Does the issue persist after restarting Unity?
It persists even after restart. Files present are octane.dat,octane.dll, octaneunity.dll,libfxdsk.dl, cudnn64_7.dll, octaneunitypackage.
It used to work for me in previous version,problem started after updating to latest version
brolly234
Any work around for this problem??
ChrisHekman
brolly234 wrote:Any work around for this problem??
577 - Damaged or improperly signed file/executable
127 - Means a dependency is missing
Both indicate something went wrong with an installation, or files are missing. The latest Octane version as new features that require the latest drivers.
- Remove the folder: C:\Users\sandeep\AppData\Local\Octane\Unity\2018.1.0f2_1.1.1.1314_T1\. (You will be promted by a reinstall when you open your OctaneUnity project)
- Re-install your nvidia drivers
Return to “Unity”
