Adding proper metallic workflow material
fatrobotsneedlove
Roeland posted a proper metallic workflow material that has 'diffuse' sections that are glossy with a 1.4 IOR so that roughness maps affect those areas of the spec map.
Is there a plan to implement this in the plugin soon?
I've attached the .orbx from Roeland.
PBR Metallic %2B Glossy.orbx
(72.92 KiB) Downloaded 229 times
4x 2080ti hybrids, 4x 980ti Hyrbids. C4D, Houdini.
fatrobotsneedlove
Nope.
The roughness values should affect the diffuse areas as if they were a glossy material with an IOR of 1.4. That's what the material that I attached in the previous post does. It was made by a core Octane dev. No mix materials. All in the metallic.
PS the new manual is fantastic, great work!
fatrobotsneedlove
So it should look like this.
My understanding was this is supposed to end up as the default, out of the box behavior of the metallic material. No mix material workarounds as in the attached graph or the substance bridge.
Having to use a mix material for every object in a scene textured with a basic PBR workflow really slows things down. Every other engine can do it with a standard material.
niestudio
fatrobotsneedlove wrote:No mix materials. All in the metallic
This it is a mix material, if you open in standalone, just double click it and you'll see the mix.
You can also add it to your local DB and then load it into C4D
OSX 10.12.4 | Intel 12 core @ 3.33 ghz | 128 gb ram | NVIDIA GeForce GTX 1080TI | Ubuntu Linux slave with 3x 1080ti
the direct PBR support in one material is going to be developed in v4,:
  • Added Universal Material node. Please note that this node is likely to change in the next few releases.
have a look at v4.00 XB2.1 release notes discussion:
viewtopic.php?f=33&t=67492&start=10#p338799
viewtopic.php?f=33&t=67492&start=20#p338885
Happy GPU Rendering,
ciao Beppe
fatrobotsneedlove
I know that, the substance bridge works the same way. They made it as an example for feedback of how the metallic material should function. Sorry I think I worded it poorly.
fatrobotsneedlove
bepeg4d wrote:Hi,
ciao Beppe
Looks like this is solved with the Universal Material.
Awesome!
