BRDF Error?
- lstudios3d
I was using the BRDF shading models to use anisotropy with the metallic material but noticed a weird render error. I've noticed something similar before but figured it was an issue with the geometry. I don't think that should be the issue here. But rendering using Octane as the model seems to render fine but all 3 of the other models have an error. Is this a bug or is there something I should check?
- Attachments
- Octane_Smooth.jpg (47.09 KiB) Viewed 1073 times
- Octane.jpg (47.28 KiB) Viewed 1073 times
- Ward.jpg (46.45 KiB) Viewed 1073 times
- Beckmann.jpg (46.08 KiB) Viewed 1073 times
- GGX.jpg (47.43 KiB) Viewed 1073 times
Are you working with the latest 3.08.1.0 plugin build? I think that some issues related to the shading have been fixed in the last couple of builds. It could be also a precision issue related to the kernel epsilon parameter, not sure. If you want to send me the scene, I could take a look at it here.
