weird render result in octane3.08 RC4 - 12.27
tkofh
Hello everyone
recently i upgraded the newest octane 3.08 RC4 - 12.27 plugin in maya,after a few test render i got this weird result
i tried everything i could think of but it won't help,anyone knows how can i fix this situation?
thanks~ ;)
Rikk The Gaijin
In the Octane camera, go into Imager and make sure you are not using any film response (set it to Linear/Off), and then set the gamma to 2.2.
When you render in the IPR window, make sure you change the output from SRGB (the default one) to RAW.
tkofh
Rikk The Gaijin wrote:In the Octane camera, go into Imager and make sure you are not using any film response (set it to Linear/Off), and then set the gamma to 2.2.
thank you rikk.it works!
BK
@ Rikk!! Thank you for your help !!
Hi, tkofh
Thanks for testing the plugin.
Here is the latest build viewtopic.php?f=109&t=67493
Let us know if you have any feedback.
Kind Regards
bk3d
Return to “Autodesk Maya”
