Noise in Render with Alpha
Houdini Integrated Plugin
sdhains
Hey Forum!
Simple question here, that I'm sure many have encountered and solved:
I can't figure out why when I include the alpha channel in my render, that I get this coloured noise around the edges of the render!
Why is this happening? How can I remove it?
here is the noise in the render:
I have attached a minimal file which reproduces the issue.
Thanks! :)
Sam
noise_alpha_render.rar
(23.69 KiB) Downloaded 193 times
fantome
i think it is because you are watching an unpremultiply image.
this mean that if you don't want to see that noise you have to check the pre-multiplied alpha image option in your render target settings.
with that option check R G B channel will be multiply by Alpha, and thus giving a smooth aliasing.
sdhains
perfect, that worked. Thanks a lot!
Return to “Houdini”
