Object speed changes mix material value OR material ID
coilbook
I know it is a bit off topic but anyway to do a float script or use parameter dialog to control octane's mix material amount with actual car speed. If car stops/slows down mix amount go to 1. Car starts moving mix amount goes to 0. I appreciate any help.
Thank you!!!
P.S
They have this for path constraint with material ID change between 1(go) and 2(stop) but we cannot use it because we yuse city traffic to make cars stop and go
braking = .96
theCar = $MaroonSedan
PositionNext = at time (currentTime + 1) theCar.position.controller.percent
PositionCurrent = at time currentTime ( theCar.position.controller.percent )
PositionPrevious = at time (currentTime - 1) ( theCar.position.controller.percent )
travel = abs (PositionNext - PositionCurrent)
travelPrev = abs (PositionCurrent - PositionPrevious)
--ID = 1
if (travel <= 0.01) then (ID = 2 ) -- standing still
--else (
else if ((travel / travelPrev) < braking) then ( ID = 2 ) -- braking
else( ID = 1 ) -- coasting
Thank you
brakes on off with path contraint.zip
(81.7 KiB) Downloaded 147 times
brake lights (2).zip
(35.67 KiB) Downloaded 198 times
coilbook
it looks like this float script work with changing material ID 1-2 when car stops and goes If anyone know how to change mix material amount instead of ID 1-2 will be great
braking = .96
theCar = $RC3
PositionCurrent = at time currentTime ( theCar.position )
PositionPrevious = at time (currentTime - 1) ( theCar.position )
travel = length (PositionNext - PositionCurrent)
travelPrev = length (PositionCurrent - PositionPrevious)
--ID = 1
if (travel <=0.1 ) then (ID = 2 ) -- standing still
--else (
Return to “Autodesk 3Ds Max”
