i've try to make an animation with rain that falls in a swimming-pool, for this animation i've use an emitter object for the rain and for the simulation of the water the mograph shader and formula deformator but when i launch octane it render always the same image, i've try to bake all the object (emitter,shader,etc) wit a looot of key-frames but always octane render don't work. I wrong something or Octane can't render this type of animation? I use r12 and octane 2.46b, thanks
Animation with Emitter and Mograph
Did you enable the option "Camera Animation"? If yes, only the camera will be updated. If not, could you please send me a test scene or post it here?Sc4rfy wrote:Hi,
Marcus
The most simple solution is always the better solution
Yes, the option Camera Animation was enable
, now all it's ok, many thanks Abstrax for your help
Edit for all: I've notice that if you use the option "Istances render" in the emitter options, octane don't render the emitters, if you deactivate this option Octane render works perfectly
Win 10 64 Bit | i7 930 | 12 Gb Ram | GTX 760 |
