Animation with Emitter and Mograph
Sc4rfy
i've try to make an animation with rain that falls in a swimming-pool, for this animation i've use an emitter object for the rain and for the simulation of the water the mograph shader and formula deformator but when i launch octane it render always the same image, i've try to bake all the object (emitter,shader,etc) wit a looot of key-frames but always octane render don't work. I wrong something or Octane can't render this type of animation? I use r12 and octane 2.46b, thanks
Win 10 64 Bit | i7 930 | 12 Gb Ram | GTX 760 |
abstrax
Sc4rfy wrote:Hi,
Did you enable the option "Camera Animation"? If yes, only the camera will be updated. If not, could you please send me a test scene or post it here?
Cheers,
Marcus
Sc4rfy
The most simple solution is always the better solution :) Yes, the option Camera Animation was enable :oops: , now all it's ok, many thanks Abstrax for your help
Edit for all: I've notice that if you use the option "Istances render" in the emitter options, octane don't render the emitters, if you deactivate this option Octane render works perfectly
